Tema: Mas pajas mentales?
  • Nikolas
    10 Nov 2013 10:42
    Nikolas » 10 FEB 2014  20:30
    He encontrado esta review sobre este juego que va a salir en consolas:
    http://www.videogamer.com/ps4/sniper_elite_3/news/sniper_elite_3_may_run_a_little_slower_on_xbox_one_than_ps4.html
    While Rebellion still hopes to achieve parity between the Xbox One and PlayStation 4 versions of Sniper Elite 3, the game may end up running "a little bit slower on Xbox One" than Sony's console, 505 Games has said.
    In an interview with Gaming Bolt, senior producer Jean-Baptiste Bolcato revealed that Rebellion was aiming to get "as close as possible to 60 frames per second on both the systems.
    "It will probably be closer to 60 on the PS4 but it drops to around 40 and 50, but you won't really feel or notice it," he said. "It may be a little bit slower on Xbox One but we are hoping to have full [parity] between the two machines."
    The Xbox One won't feature support for stereoscopic 3D either, Bolcato said, "as they do not support it yet".
    Bolcato's comments round off another bad week for Microsoft that has already seen Hideo Kojima reveal that the Xbox One version of Metal Gear Solid 5: Ground Zeroes won't look quite as good as the PS4 version.
    Sniper Elite 3 launches on Xbox One, Xbox 360, PlayStation 3, PlayStation 4 and PC in the second half of 2014.
    El caso es que dice que la ps4 tendra soporte en 3D estereoscopico.. con lo cual solo se me ocurre una respuesta coherente que es que tendra soporte para el HMD de sony??
    Juanlo » 10 FEB 2014  20:44
    No necesariamente, puede ser en una TV 3D
  • Nikolas
    10 Nov 2013 10:42
    Nikolas » 10 FEB 2014  20:58
    A sido mi primera idea.. pero es que habia pensado que debe ser transparente para el diseño del juego, es decir ya sea un Xbox o una ps4 es la tele donde se conecta la que tiene que generar el efecto 3D y no la consola.
    Me autocorrigo; efectivamente es 3D generado por la propia consola para TV, lo acado de encontrar en internet, no sabia que las consolas eran compatibles con estos rollos, y me ha podido un poco el ansia tambien
    Juanlo » 10 FEB 2014  22:46
    En la PS3 ya había algún juego, creo que el de Avatar, que se podía jugar en 3D. Recuerdo verlo en un centro comercial, y los 20 o 25 fps que daba (a ojo) lo decían todo.
  • Rafgim
    7 Ago 2013 21:16
    Rafgim » 10 FEB 2014  23:16
    Yo en la ps3 he probado en 3d Avatar, Resistance 3, Killzone 3, Uncharted 3, Gt 5, Assassin's creed revelations y alguno más, pero todos a 30 fps como mucho. Entré en el mundo del 3d probando estos juegos en ps3 y me parecieron en su momento una pasada hasta que probé el 3d a 60 fps en pc y no tiene comparación.
  • Nikolas
    10 Nov 2013 10:42
    Nikolas » 11 FEB 2014  18:26
    Me imagino que a 30 FPS y 720p la experiencia debe ser mediocre, yo he probado con el 3D generado por la TV, y la verdad es que dejaba bastante por desear.
francisco_21 IÑIGO79 4 Anónimo
