Tema: Problema DOOM 3:BFG EDITION
  • DavidPetit
    5 Sep 2013 19:57
    DavidPetit » 12 SEP 2013  21:33
    Al arrancarlo me sale un pantallazo azul con este mensaje: (Tengo una tarjeta grafica GTX 260)
    QA Timing INIT: 000114ms
    D3BFG 1.1400 win-x86 Nov 9 2012 10:38:21
    2500 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2 & SSE3 & HTT
    4096 MB System Memory
    896 MB Video Memory
    Winsock Initialized
    Found interface: {C330C348-4587-41EB-98DC-BF12F37FDBBC} Controladora de red NVIDIA nForce - 192.168.1.10/255.255.255.0
    Sys_InitNetworking: adding loopback interface
    doom using MMX & SSE for SIMD processing
    enabled Flush-To-Zero mode
    enabled Denormals-Are-Zero mode
    ------ Initializing File System ------
    Loaded resource file _common.resources
    Loaded resource file _ordered.resources
    Loaded resource file _sound_pc.resources
    Loaded resource file _sound_pc_sp.resources
    Reading resource CRCs...
    Current search path:
    C:\Program Files (x86)\Steam\steamapps\common\DOOM 3 BFG Edition/base
    C:\Users\david\Saved Games\id Software\DOOM 3 BFG/base
    file system initialized.
    WARNING: Unable to open resource file maps/_startup.resources
    ----- Initializing Decls -----
    Couldn't open journal files
    execing default.cfg
    couldn't exec D3BFGConfig.cfg
    couldn't exec autoexec.cfg
    ----- R_InitOpenGL -----
    Initializing OpenGL subsystem with multisamples:0 stereo:0 fullscreen:1
    ...registered window class
    ...registered fake window class
    ...initializing QGL
    ...calling LoadLibrary( 'opengl32' ): succeeded
    ...using WGL_EXT_swap_control_tear
    display device: 0
    DeviceName : \\.\DISPLAY4
    DeviceString: NVIDIA GeForce GTX 260
    StateFlags : 0x8000005
    DeviceID : PCI\VEN_10DE&DEV_05E2&SUBSYS_23911682&REV_A1
    DeviceKey : \Registry\Machine\System\CurrentControlSet\Control\Video\{8AAF3751-75C3-405D-AC4E-198260718B7F}\0000
    DeviceName : \\.\DISPLAY4\Monitor0
    DeviceString: SyncMaster 2243LNX
    StateFlags : 0x3
    DeviceID : MONITOR\OVR0001\{4d36e96e-e325-11ce-bfc1-08002be10318}\0002
    DeviceKey : \Registry\Machine\System\CurrentControlSet\Control\Class\{4d36e96e-e325-11ce-bfc1-08002be10318}\0002
    dmPosition.x : 0
    dmPosition.y : 0
    dmBitsPerPel : 32
    dmPelsWidth : 1280
    dmPelsHeight : 800
    dmDisplayFlags : 0x2
    dmDisplayFrequency: 30
    ...calling CDS: failed, bad mode
    Shutting down OpenGL subsystem
    ...wglMakeCurrent( NULL, NULL ): failed
    ...shutting down QGL
    ...unloading OpenGL DLL
    ...initializing QGL
    display device: 0
    StateFlags : 0x3
    dmPosition.x : 0
    dmPosition.y : 0
    dmBitsPerPel : 32
    dmPelsWidth : 1280
    dmPelsHeight : 800
    Unknown command 'vid_restart'
    Unable to initialize OpenGL
    Juanlo » 13 SEP 2013  8:27
    Tiene pinta de que no consigue inicializar el OpenGL, aunque suene a tópico, ¿has instalado los últimos controladores disponibles para tu tarjeta gráfica? Creo que los últimos son los 326.80 (he puesto el enlace de Windows 7 64 bits, si tienes otro lo puedes buscar en esa misma página.
  • DavidPetit
    5 Sep 2013 19:57
    DavidPetit » 13 SEP 2013  14:04
    Lo he actualizado por si acaso los drivers como bien me has dicho y nada me sigue saliendo el pantallazo ese azul
    Ayer me lo compre to motivado para jugarlo con mi Oculus Rift y me quedado con las ganas aver si me podeis ayudar, plis!!
  • DavidPetit
    5 Sep 2013 19:57
    DavidPetit » 13 SEP 2013  14:06
    El problema parece que esta aqui no?
    execing default.cfg
    Yo esque la verdad que de infórmatica... poquito
9 Anónimo
