Pro License Subscription (PC)
Gravity Sketch is an immersive 3D creation tool. You can create detailed professional grade 3D models, scenes, and artwork in a fast, intuitive way! From idea conception, design directly in 3D and take your models out of the scene into another design tool, CAD software, game engine, or 3D print platform. Upload your creations directly from the app to the cloud and share with others in a matter of seconds. Gravity Sketch will change your design workflow and the way you share 3D content.
Pro Subscription Features:
- All geometry creation tools
- Import .obj
- Export as .obj .fbx .iges
- Upload to the cloud
- 12 Layers
- Control point snapping
- 4 environments
For yearly subscription contact us directly info@graitysketch.com
The Pro license is for Freelancers/Educators.
*Commercial use limitations: If your company earns over $10,000/yr from work involving Gravity Sketch you are a pro user
Gravity Sketch LimitedDesarrolladores
Gravity Sketch LimitedEnlaces
