Tema: Cajón de sastre. Consejos, avisos, noticias, para hablar un poco de todo.
Parece que si tienes problemas de tracking puede ser debido a la luz, aqui una solución
Jittery tracking? There's a setting for that!
I was playing with my Quest for over an hour or so and was getting a little concerned as tracking was being fairly jittery on and off while playing. I'm not talking about where things were loading in the headset, as that was noticeable but understandable why it was happening. This was jitter that would occur during normal activity.
After going through the Settings menu, I found the 'Tracking Frequency' option. This is set to AUTO by default. I switched it to 60Hz and my tracking issues went away. I guess it was incorrectly setting itself to 50Hz, which might have has issues with the LCD lighting in my room.
Hopefully this helps others who many be experiencing tracking problems.
EDIT:
It's LED lighting I have in my room, not LCD :-)
www.reddit.com/r/OculusQuest/comments/briz7o/jittery_tracking_theres_a_setting_for_that/
El guardian se va a reajustar, demasiado cerca, a lo mejor se pasaron de precavidos.
Queria comprarme las oculus quest con el descuento de "Recomendar a un amigo". ¿Alguno sabe como conseguirlo o donde preguntar? Gracias.
Solo está disponible para Go y el antiguo Rift, al menos de momento.
VR is here!
twitter.com/RealWormSlayer/status/1130972337292140545Con esos casoplones que se gastan, normal que no contaran con el resto de la humanidad xDDDD
Pues menos mal que van a reajustar lo del guardian, porque parece que en espacios de menos de 3x3 es imposible que no salga xD
Podriamos crear una iniciativa con la referencia de ipd, es decir, crear un pagina. Alojada en realovirtual, por ejemplo, con un jpeg de lineas para ajustar el ipd.
Que os parece?
Te respondo por aquí para no mezclar con el hilo de primeras impresiones. La verdad que no tengo claro el cómo se hace lo que comentas. En mi caso me medí el IPD en una óptica antes de probar el DK1 en 2013 y desde entonces no le he dado más vueltas :P
Pero vamos cuenta con lo que haga falta para ayudar a todos los que lleguen nuevos.
Si tienes alguna idea en concreto no dudes en decirme, por aquí, privado o como prefieras.VR is here!
30 Oct 2013 23:58
twitter.com/RealWormSlayer/status/1130972337292140545Mejor porque salta a la mínima.
Nada, ya esta solucionado. Lei en reddit que no se podia volver a ajustar la ipd, despues de la primera vez, pero si que se puede ajustar desde biblioteca, tutoriales.
HaroldTe respondo por aquí para no mezclar con el hilo de primeras impresiones. La verdad que no tengo claro el cómo se hace lo que comentas. En mi caso me medí el IPD en una óptica antes de probar el DK1 en 2013 y desde entonces no le he dado más vueltas :P
Si tienes alguna idea en concreto no dudes en decirme, por aquí, privado o como prefieras. -
21 Feb 2018 13:06
¿Hay alguna manera de desactivar el guardian completamente como con Windows Mixed Reality?
La sensación de estar sin cables pero con el guardian saltando cada momento, a mi me saca completamente de la inmersión.
Me está encantando la nitidez del visor y los mandos me parecen muy cómodos y ergonómicos, pero lo del guardian me ha desilusionado completamente.
26 Oct 2015 21:20
meloncillo46¿Hay alguna manera de desactivar el guardian completamente como con Windows Mixed Reality?
Me está encantando la nitidez del visor y los mandos me parecen muy cómodos y ergonómicos, pero lo del guardian me ha desilusionado completamente.Si tienes que activar el modo desarrollador, te conectas a la aplicación movil de Oculus, luego dentro de la aplicación al Quest, y entre las opciones te sale activar el modo desarrollador, luego te pones las Quest y vas a configuración y luego a ver todo y te saldrá una opción de desarrollador y hay puedes activar o desactivar el guardian.
De todas las maneras ya ha dicho Carmack que lo van a ajustar.
Yo sigo probando, cada vez que lo pruebo me gusta mas, pedazo visor.
21 Feb 2018 13:06
Muchas gracias, lo voy a probar ahora mismo.
Edito:
Ya lo he mirado, pero tienes que dar de alta como desarrolador. Pensé que desde el móvil lo podías simplemente activar con una pestaña.
Que callados estamos, no? XD
Yo he dejado de jugar al rato que me he quedado con el cuello dolorido.
La mejor aplicación sin duda virtual desktop, se ve brutal
30 Oct 2013 23:58
Yo estoy cargándolo por segunda vez hoy ya
El cable que trae te permite conectarlo al PC?
Lo digo porque parece que las conexiones USB solo son de tipo C en ambos extremos.Vamos,,,, para ir encargando un adaptador
Ve encargando, yo he pillado un cable de usb a usb c magnético
Vamos,,,, para ir encargando un adaptador -
Luego acuérdate de estirar el cuello xD
Lo digo en broma pero tengo las cervicales cargadas
26 Oct 2015 21:20
SoukronYo estoy cargándolo por segunda vez hoy ya
Je, Je, yo también. Llevaré seis horas dandole. Estoy reventaito de probar juegos, rec room, beat saber, orbus vr, racket tennis, Sport Scramble, Creed, ....
Por cierto creo que en otro hilo has comentado que veias algunas veces aros, prueba a tirar hacia fuera el visor y a ver si asi ves menos, si es así ponte la carcasa para gafas aunque perderás 1 o 2 grados de FOV.
30 Oct 2013 23:58
AnonimoJose
Por cierto creo que en otro hilo has comentado que veias algunas veces aros, prueba a tirar hacia fuera el visor y a ver si asi ves menos, si es así ponte la carcasa para gafas aunque perderás 1 o 2 grados de FOV.Probaré. Ya digo que lo termino de colocarlo bien y me resulta pesado. Quizá cuando lo coloque bien mate dos pájaros de un tiro.
