Tema: v1.28
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 17 JUL 2018  19:09
    A nadie le importa por eso ni se postea.
    Por si a alguno le interesa :
    Software de Oculus, versión 1.28.0
    New language support
    We’ve added support across core software, including Dash, Oculus desktop app and Oculus Home, for the following languages: Danish, Finnish, Dutch, Swedish, Spanish (Spain), Spanish (Latin American), Italian, Norwegian, and Polish.
    You can change your language in the Oculus desktop app with the “Language Preference” option in the “General” tab on the “Settings” page.
    Oculus desktop app
    We’re starting to test personalized app recommendations on your Home Page.
    We’ve added per-application language pack support for developers. As developers start to use this feature, you’ll see what languages are available for each application and set your specific language pack via the app’s Library detail panel.
    Rift Core 2.0 Beta
    We’ve upgraded the Oculus Avatars with new custom hair, skin shading, clothing, and eyewear designs. You can customize your avatar from within Home: select the “Avatar Editor” mirror from the “Special Items” category and place anywhere in your Home.
    Developers who upgrade to the latest Avatar SDK will be able to utilize these new avatars in their apps.
    Tardaron 3 años en agregar Spanish.
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 17 JUL 2018  21:20
    Pues entonces a Port Zero.
  • Harold
    10 May 2013 23:05
    Harold » 17 JUL 2018  21:24
    No pasa nada, así se ve que ya no está en beta.
    VR is here!
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 8 AGO 2018  21:59
    Sigue sin importale a nadie , pero bueno , aqui va :
    Software de Oculus, versión 1.29.0
    Dash:
    A new Belt: Improved hover states and materials give the belt a more modern look and feel. Come check it out!
    We've added new contextual menus for panels within Dash. You can open them by aiming at a panel and pressing B or Y.
    Home:
    New performance improvements reduce load times and smooth rendering.
    Animation for Custom Assets: Home now has basic animation support for custom assets. Models will now loop the first animation found in the .glb file. Note that Morph Target and Skinned animations are not currently supported. More information is available in the the Rift Core 2.0 beta user guide.
    Oculus desktop app :
    Unknown sources: We are improving how we show 3rd party apps in your Library; for some apps, we are also giving users the ability to edit titles and add custom command prompts.
    Tambien hay actualizacion de firmware.
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 9 SEP 2018  10:17
    Ya se que cada dia importa menos , esto está muerto. Como sea :
    Software de Oculus, versión 1.30.0
    Dash
    We added a bunch of new design updates for improved panel navigation, management, as well as a more consistent visual treatment.
    Experiments Panel: A new experiments panel has been added to the Settings menu. From here you can try new features and product experiments (all features here are subject to change):
    Wrist Watch: once enabled, your left wrist will display the time when Dash is up. If you pin the watch, it will display on your wrist in Home and in all apps.
    Pullout Panels: Press A + Grip and pullout individual app windows from Oculus Desktop and place them anywhere.
    Remove Panel Footer: this setting removes the visual controls (chrome) on all Dash panels.
    Long Press: Sets the Oculus Button to a long press to avoid accidental presses.
    Oculus Home
    Improved graphics card support for panel streaming: The ability to stream your desktop content directly to displays in your Home is now supported across additional graphics cards.
    Summer Furniture : A new collection of 10 assets that fit a tropical summer theme. Objects include:
    Lustrous Palm
    Beach Read
    Florence the Flamingo
    Summertime Recliner
    Summertime Umbrella
    Surfboard
    One Swan-a-Swimming Floatie
    Buddy Bear Floatie
    Sidewinding Serpent Floatie
    Shabby Sharkhead
    Tutorial Improvements: Tutorials for new users should now be easier to manage with the addition of lessons in your Home settings menu. In the Interface section of settings, each section of Home tutorials is available to start individually, giving you quick access to the information you need. In addition, you can now dismiss an individual tutorial at any point in the process.
    Oculus Desktop App
    Improvements to Unknown Sources: The ability to bulk import applications, as well as re-add previously removed applications via your Library.
  • AnonimoJose
    26 Oct 2015 21:20
    AnonimoJose » 9 SEP 2018  11:49
    No me estraña, a la gente no le gusta estar relacionada con algo muerto, los continuos mensajes negativos calan. Quizas en 2022, 2023 les interese.
    oldsysopLa RV no está estancada , está muerta , a nivel masivo me refiero. (Muerta = nunca nació )
    Eso no quita que en los pequeños nichos como este el tema siga y siga.
    Supongo que la cosa cambirá para bien en la tercera o cuarta generacion , 2022/2023.
    Ademas a quien le interesa algo sobre un producto de Facebook. Cuando se largen a lo mejor.
    oldsysopEspero que Facebook anuncie que se retira de la RV.
    Que total soñar es gratis.
    cercata » 10 SEP 2018  9:10
    Hay cosas muy basicas que dejaron de tener cuando pasaron al 2.0, y que van volviendo poco a poco ... por ejemplo lo de que el reloj este siempre visible, para mirar la hora rapidamente cuando estas jugando.
    Poco a poco van remediando estas cosas, yo la verdad que estoy contento con el DASH, le he metido el Oculus Homeless para que chupe menos memoria y menos disco en C ...
    Y las cosas del DASH van mejorando, como se ueda mover el "cinto", y bastantes cositas mas ...
    La verdad es que el DASH me parece que esta muy adelantado con respecto a la competencia ... que tampoco se muy bien lo que tienen, pero no me suena que puedas meter en las APPs VR cosas 2D tan bien, y con tanta facilidad.
  • SinTonNiSon
    9 Jun 2016 18:33
    SinTonNiSon » 10 SEP 2018  13:14
    No se si es la última actualización o es un problema mío, pero no puedo abrir Oculus, me sale el mensaje: we're having trouble starting oculus, your oculus software may be updating...
    A alguien más le pasa?
    Editado: vale, ya funciona. Lo he podido arreglar haciendo esto:
    Right click taskbar > task manager > services tab > find OVRService (Oculus VR Runtime Service) > right click > Start > Then try opening Oculus Client again
    Lo pongo por si a alguien más le pasa.
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 10 OCT 2018  16:53
    forums.oculusvr.com/community/discussion/69768/rift-release-1-31-rolling-out-now-live
    Gracias Facebook por arruinarlo todo.
    Es llamativo que aqui en RoV estas cosas no tengan repercusion.
    Como lo del SPUD que nunca arreglaron y que afecta a muchas de las unidades nuevas (nuevas = las de 450 euros).
    cercata » 10 OCT 2018  17:00
    Que problema le ves ?
    Lo del Dash me parece el futuro de la VR, y lo del Home2, pues me parece una gran cagada, yo quiero que lo pongan que lo lances tu manual, pero de momento me apaño con OculusHomeless
    https://www.reddit.com/r/oculus/comments/8uf1sm/oculushomeless_use_dash_without_home_20/
    Pero vamos, soy de los pocos que parece que les moleste que te lancen el puto home de forma automatica todo el rato :(
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 10 OCT 2018  20:54
    Software de Oculus, versión 1.31.0
    Dash
    We're launching Experiments, a proving ground for experimental features aren't ready for official release. You can toggle individual experiments via the Settings tab within Dash. Some of the first experimental features available for testing:
    Oculus Desktop Window Pullout
    Wristwatch
    Window Controls
    Various design improvements to increase usability.
    Various performance improvements and fixes, including an issue with Library sorting
    Home:
    New themed item collections: Spooky, Pirate, and Retro-Modern.
    Customer Developer Items
    Developers can now give out special Home objects and decor as gameplay rewards and achievements (live with initial partners, opening to all developers soon).
    User generated content
    Home now supports the playback of skinned animations for user generated content
    Fixed an issue where user generated content would sometimes not show up in Home
    We've revamped the UI to improve usability.
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 10 NOV 2018  14:25
    Cero interes genera  , pero va igual.
    Software de Oculus, versión 1.32.0
    Dash
    Menu Improvements: Added a new Dash rollover menu. Hover your pointer on the right side of the belt for instant access to volume, Touch status, and to re-center your view.
    Oculus Home
    Embedded Panel Support for Custom Objects: You can now add embedded panels to custom 3D objects for importing to Home. This currently only works for solo users.
    Home Menu: Updated fonts and added new localization options for improved functionality and visuals.
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 14 DIC 2018  17:41
    Cada dia un poco mas muerto todo.
    Software de Oculus, versión 1.33.0
    Dash:
    We've added a new system keyboard to Dash. You can access it by clicking on the keyboard icon at the bottom right of any virtual desktop window.
    We've updated Dash's background environment with new textures and lighting.
    Home:
    You can now report offensive behavior and content within Home. Use the context menu or social panel to initiate a report.
    We've added a new collection of festive items to celebrate the holidays! *
    Assets include:
    Decorations
    Lodge Sofa
    Lodge Armchair
    Antique Sled Table
    Lodge Rug
    Rustic Dining Stool
    Rustic Island
    Rustic Long Counter
    Rustic Square Counter
    Rustic Long Shelf
    Rustic Short Shelf
    Rustic Bookcase
    Comet
    Cupid
    Mistletoe
    Cheerful Centerpiece
    Winter Wreath
    Christmas Stockings
    Regal Buck
    Snowflake the Snowman
    Popsicle the Snowpup
    Menorah
    Kinara
    Mkeka
    Objects
    Muhindi
    Unity Cup
    Gimmel the Dreidel Plushie
    Christmas Present
    Tales for the Winter Solstice
    Cheerful Throw Pillow
    Joyful Throw Pillow
    Environment
    Ceiling Winter Cabin
    Details Winter Cabin
    Floor Winter Cabin
    Wall Winter Cabin
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 15 FEB 2019  5:08
    Software de Oculus, versión 1.35
    Changes:
    HOME:
    Custom Home Support: You now have the ability to import your own Home geometry as a replacement for the standard “cabin” geometry. Just like importing your own custom items, you can place a .glb file in your My Imports\Custom Homes folder and use that object as a template for brand new Homes! We've also implemented new ambient audio tracks to apply to your custom Homes, as well as a lighting panel to adjust the interior and exterior lighting (depending on which types your space implements). Full documentation of this feature is coming soon.
    DASH:
    Various performance improvements and bug fixes.
    If you encounter any issues with this PTC software release, please be sure to report them using the Help Center > Provide Feedback option within the Oculus desktop software. If you have any feature or enhancement requests, please leave those on our UserVoice page. Thanks!
    cercata » 15 FEB 2019  8:41
    El fichero .pak del HOME ha pasado de 7.8GB a 9GB, y no se puede mover a la biblioteca ... va a Ocupar mas el puto HOME que un juego Sandbox, y no lo ponen opcional, ni con el resto de Apps :(
  • forastero
    20 Ago 2016 01:54
    forastero » 10 MAR 2019  20:17
    Hola foreros.
    Acabo de actualizar mi PC para Oculus que no he podido usar desde julio 2018, y ha habido muchos cambios, para bien o para mal.
    Una pregunta: ¿habría alguna manera de que al lanzar el home se inicie el escritorio virtual, sin tener que coger un touch y tocar el botón correspondiente?
    Gracias. Un saludo.
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 12 MAR 2019  0:20
    Software de Oculus, versión 1.36
    Changes:
    Home:
    Sound Objects: Fill your Home with sound by placing new sound objects. Select from an initial pool of nature, sci-fi and other sounds to add effects and enhance your space. Sound Objects can be found in the audio section of your inventory.
    Gateways: Create an easy link between your own Home and other Homes with a Gateway. Place anywhere in your Home to expand your space and connect different themed rooms or public Homes. Find Gateways in the Special Items section of your inventory.
    Performance Improvements: Miscellaneous graphics updates for improved performance with medium and low settings across devices.
    Lo de siempre , igual a nadie le importa.
    altair28 » 12 MAR 2019  13:54
    Hay una noticia actualizada el 7 de marzo con esta información
    www.realovirtual.com/noticias/6457/actualizada-1-36-rift-anade-objetos-sonido-portales-otros-home
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 18 MAY 2019  1:43
    Software de Oculus, versión 1.37.1
    Changes:
    Home:
    Tutorial refresh: We've polished up the new user tutorial in Home to be more lightweight and dynamic, as well as offer rewards for completion. If you are not a new user and want to check it out, find it in your settings menu.
    UI revamp: We've updated the user interface for a consistent look and feel, and to make navigation and browsing more intuitive.
    Expressive Avatars Update: Avatars have been updated to simulate eye and mouth movement, making a simple conversation feel more dynamic. And with new outfits and customization options like eye color and lipstick, spending time with others in VR will feel more personal and authentic.
    Dash:
    Screenshot capture in VR: Capture screenshots from inside your headset by pressing the 'screenshot' button located on the menu on the right side of your Dash belt. There is a 5 second timer to set the pose and position of the screenshot. Images will be saved out to your C:\Users\*User*\Pictures\ directory. Happy screenshotting!
18 Anónimo
