Tema: Open Store VR - Now sideloading is a breeze with Oculus Go / Quest.
  • Usuario eliminado (9543)
    18 Jun 2018 21:44
    Usuario eliminado (9543) » 21 MAY 2019  9:21
    It comes in two parts, a desktop app to browse and install apps with things like connection status and an experimental wifi mode.
    Then on the device you have a companion app launcher that runs in oculus TV that lets you see all the apps on the device. ( I couldn't get a screen shot so below is a through the lense shot. ). It allows you to access a bunch of native hidden stuff like the native android settings menu, a file manager and various other things. I have used it to install apps like discord, MS Word & Excel, Whatsapp - all the boring ones really. I plan on adding tonnes more and the whole thing will be open source.
    www.reddit.com/r/OculusGo/comments/bqnu47/open_store_vr_now_sideloading_is_a_breeze_with/
    cercata » 21 MAY 2019  9:27
    Está probado en Quest ya ?
    18 Jun 2018 21:44
    Usuario eliminado (9543) » 21 MAY 2019  9:30
    cercataEstá probado en Quest ya ?
    De momento no, he hablado con el desarrollador y dice que esta puliendo algunos fallos. Para el final del dia dice que pondrá la descarga.
    18 Jun 2018 21:44
    Usuario eliminado (9543) » 21 MAY 2019  23:04
    Open Store VR - Sideloading made easy!
    I posted yesterday about an app store concept I was working on, it still needs lots of things done to it but I said i would get it out there and see what the feedback is on it. You can find the download for your platform at the following link. There is a mac and linux version included ( mac is untested i'm hoping someone can help me out there ).
    github.com/shaneharris/OpenStoreVR/releases/tag/0.0.2
    It is still very much in beta so there will be issues! If you have any issues please report them here and i will try to get them fixed as soon as i can - github.com/shaneharris/OpenStoreVR/issues
    Remember to follow the instructions in the setup screen to get started. It is particularly important to install the Open Store Launcher app to be able to launch your apps on your device once they are installed. Once this is installed you'll find it under Library > Unknown Sources ( left menu ) > Open App Store
    This app is brought to you by the lead developer of The Expanse - a social VR building game with lots of power!
    Follow Us!
    www.patreon.com/TheExpanseVR
    discord.gg/Q2a5BkZ
    twitter.com/TheExpanseVR
    www.youtube.com/c/TheExpanseVR
    www.instagram.com/TheExpanseVR/
    theexpanse.app
  • Hypernova
    28 Mar 2019 06:37
    Hypernova » 23 MAY 2019  18:21
    ¿Esto serviría para retrocompatibilidad con Go?
  • RescueGamer
    4 Jun 2013 00:37
    RescueGamer » 23 MAY 2019  18:34
    Lo de quest es surrealista, esta pillando una velocidad de infarto. Con el catalogo de go y gear vr gana unos cuantos enteros, y eso sin contar que parece ser que los juegos de go y gear vr ganan posicionamiento absoluto ejecutados en quest incluso en las manos! Obviamente generara fallos en algunos juegos ya que no estan pensados para ello y mekos roomscale, pero mucho mejor que tenerlos solo con 3dof xD
    18 Jun 2018 21:44
    Usuario eliminado (9543) » 23 MAY 2019  21:04
    Hable con un usuario y muchas dan fallo porque el mando no tiene trackpad.
    Probados que van son el minecrafr de gear VR y el quake port de gear VR tb
    18 Jun 2018 21:44
    Con que solamente pille los micro movimientos de la cabeza me conformo
  • Hypernova
    28 Mar 2019 06:37
    Hypernova » 24 MAY 2019  0:16
    Menos mal, me mareo en Go si muevo la cabeza. Solo debo rotarla.
  • Soukron
    30 Oct 2013 23:58
    Soukron » 24 MAY 2019  0:34
    A mi me funciona la aplicación, me ha permitido meterle el launcher de aplicaciones, pero no me carga la lista de aplicaciones ni juegos ni experiencias para hacerles sideload. No tengo claro de donde debería estar cogiendolas, pero no las carga.
