Tema: Confirmado. Los Servicios de Oculus no recopilan informacion personal de los usuarios
  • AnonimoJose
    26 Oct 2015 21:20
    AnonimoJose » 5 ABR 2016  22:56
    Un usuario ha hackeado Oculus home y tras analizar el trafico de red ha verificado que se envia la siguiente informacion:
    -Logs if Oculus Home hits an Error
    -The amount of time it takes Oculus Home to open after telling it to start opening
    -Your minimum, maximum, and average frame rate
    -How long it takes to enter or exit a subsection (subsections include the home environment, setup, the grid room, safety warning, etc.)
    -The application that sent the analytics, the version of Oculus Home that sent it, the version of the Oculus Plugin that sent it.
    -How long it takes to close Oculus Home
    -How long you spent in Oculus Home total
    -Amount of memory usage (may only be when an error is sent)
    -What VR application you have open (if any) that was launched from Oculus Home
    -Oculus Waterfall (no clue what this means, but seems related to in app purchases)
    -When you start an in app purchase (I'm pretty sure an in app purchase means buying anything in the Oculus store, including games)
    -If you cancel an in app purchase
    -If you make an in app purchase
    -How much the in app purchase cost
    -If you failed to enter your pin correctly during an in app purchase
    -How much time you spent on each section of making an in app purchase
    La conclusion a la que llega el usuario que ha hecho el hackeo es que Oculus no esta guardando informacion a la que no deberia tener acceso. Y que no hay ninguna informacion que te pudiera identificar personalmente al margen de la que se pudiese almacenar en ficheros logs. Ficheros que muchas aplicaciones y juegos envian automaticamente cuando tienen un crash. Mirando sus logs ha visto que Oculus evita la informacion confidencial en los logs lo maximo que les es posible. Dice que la mayoria de la informacion es para mejorar el software o detectar cuelges largos. Visto todo, dice que Oculus recopilas una informacion muy razonable/sensata y significativamente inferior que la que se te recopila cuando navegas con tu navegador por internet sin un bloqueador de anuncios.
    Dice que espera que esto ayude a la gente a quitarse algunos miedos y que si alguien ha detectado algo mas que se lo diga.
    A esto otro usuario le replica que el tambien ha hackeado Oculus home y ha detectado esto tambien:
    Direct Display capability.
    CPU Information (Manufacturer, Model, Cores and Clock Speed).
    Video Card Information (Manufacturer, Model and VRAM).
    Operating System Version.
    USB Controller Driver Version and hardware information.
    Unique Machine Identifier.
    Timestamp
    Y tambien indica que no se esta enviado informacion personal que pueda identificar a los usuarios
    Este es el hilo de reddit con toda la informacion www.reddit.com/r/oculus/comments/4ddj1g/what_oculus_network_traffic_contains/
    7
  • Adel
    3 Jul 2013 11:48
    Adel » 5 ABR 2016  23:27
    Gracias por informar!
    Al final, lo mismo de siempre, mas humo y mas mierda que nos vendieron los anti Facebook. Ains Dios, que de trolls...
    8
  • Cuco
    15 Oct 2014 00:06
    Cuco » 6 ABR 2016  0:01
    Gran aporte AnonimoJose.
    Muchas gracias!
  • imho
    7 Mar 2014 06:22
    imho » 6 ABR 2016  0:24
    No es de extrañar,la verdad...por no hablar de que la mayoria de recopilaciones de informacion de sistema y logs,que suelen utilizarse en versiones iniciales de software,se realizan con el fin de identificar problemas y evitar una ola masiva de reportes o solicitudes al soporte.
    A veces,incluso dejan de realizarse con el tiempo,pasadas las primeras recopilaciones.
  • oldsysop
    21 Jul 2013 11:34
    oldsysop » 6 ABR 2016  7:26
    AdelGracias por informar!
    Y cuanto les han pagado a estos "usuarios" para mentir defendiendo a Facebook ?
  • Adel
    3 Jul 2013 11:48
    Adel » 6 ABR 2016  8:38
    La pescadilla que se muerde la cola...
  • iruss
    16 Jul 2015 20:40
    iruss » 6 ABR 2016  12:12
    y cuanto han pagado a los usuarios para decir que mienten esos usuarios defendiendo facebook? y así hasta el infinito y más allá, seamos serios, si no se tienen evidencias o noticias reales es como si dijéramos que Palmer es reptiliano ( por eso lleva chanclas) y nos quedamos tan anchos..
  • SdReNe
    16 Ene 2016 21:52
    SdReNe » 6 ABR 2016  14:20
    Ignorad a este tío por favor. Viene aquí a lo que viene, obvious troll is obvious
5 Anónimo
