Tema: Audio doesn.t work if I use steam version with steam link for quest 3
  • sariddu
    9 Mar 2021 12:50
    sariddu » 4 DIC 2023  1:18
    The steam version of Propagation: paradise hotel works properly with quest 3 by using airlink but if I use steam link for quest 3 the games start correctly but the audio doesn't work. Any solution ?
  • ROM007
    9 Oct 2013 15:07
    ROM007 » 10 DIC 2023  20:44
    I was able to fix mine by taking the following steps:
    Open your sound control panel:
    - press win+r and type/paste `mmsys.cpl` and press ENTER or click OK.
    - Click the `Playback` tab.
    - Right click Speakers Steam Streaming Speakers and click Properties
    - Click Advanced and Change the Default format to 32 bit, 48000 HZ (Studio Quality)
    - Click apply.
    - Repeat the same steps with Speakers Steam Streaming Microphone (if you have it, mine required it as well.
    - Restart Steam/Steam VR
    This should fix no audio/crackling audio issues. Additionally, make sure the speakers are default device, and microphone is default communication device if you still are having issues.
    From Kodfod user.
